Toggle navigation
Categories
Discussions
Sign In
Home
AMX General Discussion
Displaying an integer
kmenshouse
32
September 2007
in
Is there a way to set the number of places for an integer, so you can send two digits to a display, with the first being zero?
Keith
Joe Hebert
2,159
September 2007
Yes there is. Check out the FORMAT command. It would be something like:
FORMAT('%02d',nMyInteger)
Chip Moody
727
September 2007
Heh. Before the FORMAT command, I used to do something like pad_num = RIGHT_STRING ("'00',ITOA(my_integer)",3) to - for example - get three digits at all times, even if the first one or two were a leading zero.
Sign In
or
Register
to comment.
