Double Step Satellite RX
Greetings all...
Here is a 'strange' one. We are controlling a Bell ExpressVu (Canada) satellite receiver and are getting a 'double step' on the IR pulse for channel up. Doesn't seem to happen on left/right, but up/down will step up two channels. Press the KP and the channel will go up, up. It is not jumping by 2, but is going up 2 steps.
Any ideas? Could this be 'bad' IR code?
Anyone have an IR file for the Bell ExpressVu 3100 that works for them?
IR emitter is covered with shield to prevent IR bleed to other RX units.
Software is staight forward - pulse time is left at default.
BUTTON_EVENT [dvKPPro, 96] // Pro Shop TV Chan UP
PULSE [dvIRSat2,14]
PULSE [dvIRSat2,14]
Shorten the pulse time:
SET_PULSE_TIME(2)
PULSE [dvIRSat2,14]
SET_PULSE_TIME(5)
See if that works!
I find that people tend to be pretty good at timing the hit themselves. And if they want to hold down the channel up/down or volume up/down it works a lot better anyway. It also helps avoid the very problem you're encountering. If you use PULSE you'll find that you'll need to adjust the pulse time in the code. Keeping track of that can get a little tricky and you may end up shortening the pulse time when you do need it long.
If you just let the user do the button hit, they figure it out quite well.
So for example...
I'll give both a shot. I may try to pulse time change first versus the TO as I am currently dealing with the new Modero DMS keypads and discovering that the buttons are not really as good as I would have expected. (nor are a few other things!)
I appreciate the quick suggestions!
Cheers!
Those wanting to do what Eric is suggesting, I would intervene and say use MIN_TO and not TO. MIN_TO has a minimum amount of IR that will be spit out - and this is controlled by the SET_PULSE_TIME. (Typically I set this to 2). But, otherwise, I use the SP command and set CTON / CTOF.
That would be the safe thing to do. I just have never had anyone who consitently hits the button less than 2/10ths of a second. I've never once had any problem using TO. But, to the point, that is correct. MIN_TO will ensure that you get a good IR flash.
And as we all know, "Those who claim something to be fool proof underestimate the ingenuity of fools.."
I usually use the SP command when spitting out the IR and set cton to 3 and ctof to 2.
