Trying to connect to NI-700 with browser
rdriederrdrieder Junior MemberPosts: 25
Getting this message after logging in:
"The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later."
Any ideas?
  • Marc ScheibeinMarc Scheibein Junior Member Posts: 677
    What browser are you using?
    Opera has problems to handle XSL in general, but if you use the direct URL to a WebControl file, it will work. Internet Explorer 6 and 7, and Firefox will work fine.
  • dchristodchristo Junior Member Posts: 177
    I occasionally get that error using IE6, but in almost every case hitting the "refresh" button in the browser will correct it.
    --D
  • rdriederrdrieder Junior Member Posts: 25
    Re: Trying to connect to NI-700 with browser
    I'm using IE6 and the refresh button doesn't change the error message. I can connect and control the NI-700 using Studio.
  • Joe HebertJoe Hebert Junior Member Posts: 2,159
    If you are using DUET firmware you may want to try and increase the DUET memory allocation with the SET DUET MEM command via telnet. I had problems with the masters' web interface before I increased the DUET memory size even though I wasn't using any DUET modules. Check out tech note 766.
    RE: Trying to connect to NI-700 with browser
    I tried that, all the way up to 8M. Still no luck.
