Two NI 700, One TP
I have a system with two NI 700's and one TP. These are connected over IP. On a button push I need to be able to to send strings to the 232 port's of both the masters, like power on of plasma's, make a route on a switch, control a xap etc. Any idea's on how to do this.
  • Jeff BJeff B Posts: 37
    I would use a dev array.
    dvDEVICE_1	=	5001:1:1	// Serial device on system 1
    dvDEVICE_2	=	5001:1:2	// Serial device on system 2
    dvTP		=	10001:1:0	// Touch panel on system with the program
    // this is the dev array
    DEV dvDEVICE[]={dvDEVICE_1,dvDEVICE_2}
    BUTTON_EVENT[dvTP,1]
            // This will send the string to both serial ports
    	SEND_STRING dvDEVICE, "'STRING TO SEND TO BOTH'"
    JB
  • AMXJeffAMXJeff Posts: 450
    You also have to remember to set the masters up in master to master mode. It is obvious with Jeff's code below, but wanted to make sure you knew that...
    JB
    This code would allow for sending a serial string to each device individually.
    INTEGER nBUTTON_ARRAY[]={2,3}
    BUTTON_EVENT[dvTP,nBUTTON_ARRAY]
            STACK_VAR INTEGER nBtnIdx
    	// select system to send serial string too
            nBtnIdx = GET_LAST(nBUTTON_ARRAY)
    	// Send to serial device on selected system only
    	SEND_STRING dvDEVICE[nBtnIdx], "'STRING TO SEND'"
    JB
  • Master to master mode
    Thanks for the help, only one other question
    How do you configure the masters for master to master mode?
    To set master to master mode:
    Give each master a unique IP and system number. See tech note #348
    In the URL list for one master, add the IP for the other master. See tech note #401
    Done.
    JB
  • Thanks
    Thanks for the help.
