Panasonic Multi Cell Phones
Does any one know what the actual operating frequency range of the Panasonic Multi Cell phones is? I want to know the specific freak range in the 2.4 GHZ band.
Panasonic no longer produces the 900 MHZ phone system phones which means I'll have to start using the 2.4 GHZ multi cell which are infinitely a better cordelss system and from all I've heard doesn't present an interferance problem with wi-fi networks. I not sure how true that is so I've always refrained from their use and opted for the tried and true 900 mhz.
I assume the reason the muli cell cordless don't interfere is because they operate above 2.473 MHZ which is upper bandwidth freak of wi-fi channel 11 (US highest channel). Now we have to be concerned w/ ZigBee allocations which ideally would operate above wi-fi channel 11 on ZigBee channels 25 or 26. Now if the Panasonic operates it this range we'll probably have issues. We could use ZigBee channels 15 & 20 if and only if we subscibe to the AMX 1-6-11 wi-fi philosophy, I don't. I prefer the 1-4-8-11 Cisco approach and then shift repeating channels by 1 because RF doesn't follow those neat little cirlces than are illustrated on the site survey patterns. So for me use of ZigBee channels in the wi-fi range trying to spot a hole in the frequencies isn't practical.
So if anyone knows the freaks of the Panasonic multi cells I'd appreciate it if you'd let me know so I can make a logical attemp of cramming all this sh t into this 100 mhz bandwitdh of the 2.4 GHZ range.
See original post.
They operate from 2401 - 2480 MHZ @ 0.40 watts which is the same freak range as wi-fi. So it's likely they do interfere with wi-fi but it's just one of those things that's hard to notice. Once I actually install a network and this phone system in the same job I'll have to run some test to see what sort of negative interference if any there is. If I purposely force a confrontation between the two systems something is bound to hiccup.
If no one has noticed any ill effect yet it probably won't be that bad. I'll likely have to have the phone on top of the WAP or MVP while placing call with Netstumbler or WI-SPY running in the background to see anything.
Fortunately the Panasonic operating frequency shouldn't cause any interference w/ ZigBee when using ZigBee on channel 25 or 26 which was my real concern. Using ZigBee on the lower channels will be a crap shoot not only with the phones but with the wi-fi as well unless you do the wi-fi 1-6-11 and the ZigBee 15 or 20. Then wi-fi won't be an issue but the phones might be.
At the time, I managed to talk with someone in tech support at Panasonic trying to find out what frequency the phones use, and my answer was: "All of them". I tried to find out if it jumped frequencies based on interference or some other algorithm, but all he would tell me is "All of Them". We also had 8 handsets installed, so if they used a different channel for each phone, 8 of the channels would have possibly been in use.
Now that I think about it, I'd love to take my Wi-Spy unit back there and see what's really happening
Vining: Do you have an update on this situation with the new Panasonic phones, wi-fi and zigbee possible interference? I'm about to quote a job where all of them are going to be involve and I'm just wondering what kind of problems I might encounter.
ZigBee and WiFi should be fine if you only use ZigBee channels 25 or 26 and create a single mesh network as ZigBee 25/26 is above the US WiFi allowed range.
I first locate my acces points and try to get them as close to the area where the MVP will reside and be used most of the time. I've had issues in the past where I would place access points where they made sense in an overall scheme but later found that in the prime area for using the MVP TP I created a Bermuda Triangle of coverage where three APs were at almost identicall signal strenghts to the panel and the panel would constantly drop offline and switch from one to another, not good. Obviously a firmware problem in the MVPs so I moved one into the same room to give the TP and obvious choice.
Then I would locate my ZibGee gateway and repeaters. I don't know exactly how these handle traffic but there range is probably three times that of an AP. Try to keep everything as far apart as possible (AP,GateWays, Cell Station) and cross your fingers.
I'm more confused now. I just check my training book for the KX-TDA system and in the Site Survey precautions for the sell stations states:
I'm going to need to call my friend again this morning to see what he saids about this because when I asked him about it yesterday he told me that he was 100% sure that the CS were working from 6 to 11.
If we go by the rules of 5 channel separation between access points to avoid interference between them, we could assume that the cell stations are working around channel 4.
Here is a link to the image they have of the recording. http://www.metageek.net/Support/Docs/Recordings/Cordless_Phone__Wi_Spy_2_4x_/
In the image, you can clearly see how the phone transmission hops around.
We've had all kinds of trouble with Panasonic phones and WiFi. This was mentioned in another post.
From August 2007 Consumer Reports
