Aprilaire RS-232 control
Hi all,
I've got a problem with some Aprilaire thermostats. I'm using the AMX module for all my control and state tracking. The problem is that the thermostats seem to, after a very short time, sort of lock up and become unresponsive to commands from the controller.
I've done a bunch of reading on the forums here to see if anyone else has had the same problem, and it sounds as though I might be polling them too often. Currently, I'm polling them for mode, set points, and temperature every 30 seconds, but from what I've read, it sounds like this is maybe causing my problem and that I don't actually need to poll them at all. Can anyone verify that this is the case, or help me work out what I'm doing wrong?
Thanks in advance.
Thanks in advance.
On the hardware side you there's alot of steps that should be taken as far as wiring and addressing to minimize comm problems. Address everyone sequentially starting at 1, put the total number of stats in each tsat in their individual set up. Use a seperate power supply to power your stat at the dist panel, if you have more that one dist panel you'll likely need a second power supply in which case you might consider using the REF termial to tie the ground reference through to all device.
These stats can be very finicky so you have to ensure that every set up step is adhered to.
As for power supplies, that's really beyond what I even know how to do, but I'll talk with the installers and see how it's all set up.
For now, I'm going to remove my manual polling code and see if that helps.
It is possible you have a problem on your comm buss as well. I just recently had a system where the data appeared to be locked ... all the stats on the site showed no communications. I found one stat buried in a mechanical room that was in an endless re-boot cycle (good for me it wasn't controlling a furnace, it was just there to monitor the temperature and humidity). It turns out someone had connected the wrong wires to it's external sensor terminals, and that was causing the reboot. The annoying part was that one stat having an issue took down the entire system. This kind of thing is pretty much par for the course with the 8870, sadly.
Excessive polling is definitely another issue, and produces the same effect. the 422 buss is simply not managed very well. Any excessive traffic (be it legit notifications, or reeboot activity) shuts the whole thing down. It's reliable enough when all is well, but I am sorry to say, I would not entrust these thermostats to any kind of critical system. Heck, if my home gets a bit too cold, I will notice it and can temporarily shut down comms until it is fixed; but the wine cellar with those vintage bottles ... or the computer room ... no, I would absolutely not trust an 8870 that far.
Just want to follow up on how this turned out. Once I took out my polling routines, everything started working famously. Well, I have one stat that's sending back garbage strings when I try to talk to it, so I have either a bad stat or a bad wire there, but everything else works great now.
Thanks for all the input and advice.
