TPI4 firmware
We have problem with Elo touch monitor (model ET 1529L), connected to TPI/4 (firmware v 2_57_69). Monitor show image, but TPI/4 doesn’t receive pushes. How to solve this problem?
  • ossv@texpo wrote:
    We have problem with Elo touch monitor (model ET 1529L), connected to TPI/4 (firmware v 2_57_69). Monitor show image, but TPI/4 doesn?t receive pushes. How to solve this problem?
    Is the screen USB or serial?
    The TPI4 I have here is firmware 2.63.4 and has 2 Elo drivers, ELOTOUCH and ELO19TOUCH. Not sure if both are implemented in the 2.57 firmware, and what's the difference.
    A list of tested touchscreens can be found here http://www.amx.com/techsupport/techNote.asp?id=643
    Regarding the firmware update to 2.63.4 see end of the above Technote.
    This is from the Technote from v2.63.4 firmware, additionally supported drivers:
    Element One (serial)
    Eizo 17 inch Flexscan (usb)
    Smart ID350 (usb)
    Wacom DTF-521, DTF/PL 720 (+ many others - none to validate with) (usb)
