Expansion Cards
Hi,
I have a NI-4000 with extra comm expansion cards. I have standard extron device hanging off these, but when I try and put a NEC LCD 4010 onto one of these - I don't seem to be getting control ? Out or In. If I move the NEC LCD 4010 to Serial Port 7 built in it works fine ??
The only difference I can see is the 'String Size' which is 196bits on the card but only 64bits on the in built ports ???? This stat comes from check port.
Any ideas...
Ed
  • yuriyuri Posts: 861
    does the card "come online". ie. do you see it in your online tree?
    I've had once i had to press the cards in violently (sort of) to get them "clicked" in
  • Push
    Hi,
    Yes the cards are in - if I send a strin I can see the red led light up. The problem is I have put this LCD onto a card which normally controls a extron switcher perfectly...
    Ed
  • glr-ftiglr-fti Posts: 286
    I've been having a similar problem with a Pentair Intellitouch. Works fine in the DB9 Port 1-7 but failed in the COM2 slots. I played around with a breakout box and figured out I needed to connect DTR, I think it was, in order to get communication to the Pentair. It may be a similar situation for your device.
    Are you making sure to put the 'SET BAUD' command in an online event of a DATA_EVENT[whatever_your_card_is] as opposed to the DEFINE_START section of the program?
    You can check the settings of the card in terminal by sending a GET BAUD command and watching the diagnositics.
