Can't Find Cable
I've got a bunch of projectors (Sanyo PLC XU48) that don't have a D9 RS232 jack on them. They've all got 8pin miniDIN connectors. I'd really rather not make my own cables for all of these, I'd much rather buy 8pin miniDIN to D9 short cables and putting my own D9 extension cables. However, I can't really figure out where to find these cables anywhere. I've seen cables with those two ends for specific devices, but I can't find pinouts for exactly what they are. Does anyone know where I can find this?
J
J
Sanyo sells the cable you need, the model # is POA-MCSRL. "List Price" is $40.00.
Any Sanyo LCD dealer should be able to supply these cables for you.
Sanyo LCD Dealer Locater: http://us.sanyo.com/business/projectors/dealer.cfm?showFileID=407
Regards,
Little soldering required, but it beats the 40$ price-tag the original cables have
I will check out manufacturer + part number for you tomorrow
EDIT:
Intronics, it's an Apple 8 pin mini din cable
Sorry for the ignorant questions
J
I've got a bunch of these (the ones that actually come with the projectors).
I dont use them because we usually snake the control cable through the
mounting pipe, and these usually have a big ferrite bead on them.
The projector series is what makes the difference as to whether or not a control cable is included, and as you discovered the XU's are not shipped with an RS-232 cable.
Projectors that are not shipped with RS-232 cables include all ultramobile units (XU, XW, XL) and the smaller "home theater" projectors.
If you are still in need of the protocol, go to this URL and you can download protocols for the entire line (minus the new DLP models??). Also available are the IR codes, drawings, and lamp lists.
http://us.sanyo.com/lcd/
Steve Rynbrandt
edited to add URL, oops!
For example, if you go to sanyo's website and find the XU48 projector, there's no link to the protocol there. Why on EARTH would it not be linked there?
Bleh. Stupid manufacturers
