Has anyone interfaced with a Centralite lighting system? Any feedback negative or positive will be greatly appreciated.
Yes. Very easy. NetLinx system with a whole bunch of DMS keypads. RS-232. Ginormous Centralite Elegance system in two houses with zillions of loads and scenes. The way it was set up, only one serial connection is required. I send a command that indicates which system (A or and which load or scene by number, On or Off.
I agree very easy. Have a starlite system controlled by 2 12" inwalls and a NI3000. The only snag i had was if you do a scene it snds the feedback back real fast you need to make a que for the feedback and parse out 1 at a time for the loads.
It's that simple.
Eric
