parsing multiple data out of 1 large piece of data
gentlemen,
please bear with me as im still relatively fresh out of prog II. i have stared endlessly at the following chunk of data:
ESCX200304200030010037Aventura ft Frankie J - Unknown Album00030010027Berlin - Top Gun Soundtrack00030010025Chris Isaak - Wicked Game00030100022D'Angelo - Brown Sugar00030010019DMX - Unknown Album00030010022Dominic Marte - Ven tu00030010022Drowning Pool - Sinner00030010029El Gran Combo - El Gran Combo00030010029El Gran Combo - Nuevo milenio00030010029El Gran Combo - Unknown Album00030010044El Gran Combo de Puerto Rico - Unknown Album00030010024George Michael - Unknown Album00030010042Gerald Levert, Eddie Levert - Private Line00030010016Godsmack - Awake00030010034Jagged Edge - Jagged Little Thrill00030010027Jagged Edge - Unknown Album00030010021Jay Z - Unknown Album00030010020Jay-Z - Kingdom Come00030010021Jay-Z - The Blueprint00030010021Jay-Z - Unknown Album00030010042Jessica Simpson - I Wanna Love You Forever
This is from an escient fireball (i know theres a module im using this as a learning tool)
i need to obviously get the artist/song data out of here (im hoping to display this as a list of available albums) i eventually want to organize these albums (theres many many more in the database im just showing this sample) into some sort of data structure/array to then populate the TP.
i dont know where to begin?? every string parsing idea i come up with falls short. Has someone come up with a slick way to handle large dynamic data like this & can share some pointers??
thanks again!!
thanks again!!
yes i have the escient module, but there is so much going on in there (4000+ lines of code) that i cant clearly follow and or understand what they are doing. Thats why ive taken the approach to re-do some portions of the module small piece by small piece.
thanks
The first step I would take is to grab a single complete command. Once I have the command, I would start to disassemble the command and handle it appropriately. For this instance, I would remove the preamble. Then I would grab the command group and sub command. Based on the command group and sub command, I would then handle the data as is needed according to the protocol document.
Hope this helps,
i do have the protocol documentation and i am familiar with the command structure. I can parse 1 song/album and send it to a panel. Where i get stuck is parsing through a huge chunk of data and pulling out say 30 album titles to show a list of albums on a given media server.
thanks again.
This happens to be one of the more involved protocols out there. I understand that you are trying to take only a little portion of the module and deal with just that piece, but as I recall, you have to deal with a lot of tracking to make the communication and control function properly.
Hope this helps a little,
We could only wish. Actually, the 0003001 means "the next piece of data is 3 digits long, and that data is 001." You can't guarantee it's always going to be that, though it often is consistent in a specific context. In this particular example, it is followed by the length of that one piece of data, the title, so the next four digits are the length of the title, followed by the title itself. Their entire protocol is like that. They always tell you how long the data segment will be just before sending the data itself, but it gets confusing when the "data" is the amount (not length or size, but amount) of data they will be sending ...
the following is quite ugly but this sucker works-- at least for 1 go around, it will list the first 10 albums in the fireball, organized in a data structure/ array:
DATA_EVENT[0:dvFBPORT.PORT:0]
STRING:
SEND_STRING 0, "DATA.TEXT"
(* SET STRING *)
IF(FIND_STRING(DATA.TEXT,"13",1))
strRESPONSE = DATA.TEXT
TEMP_BUFF = GET_BUFFER_STRING(strRESPONSE,20)
TEMP_BUFF = ''
FOR (nFBLOOP=1;nFBLOOP <= 10;nFBLOOP++)
TEMP_BUFF = GET_BUFFER_STRING(strRESPONSE,9)
TEMP_BUFF = ''
nDATA_LENGTH = LEFT_STRING(strRESPONSE,2)
TEMP_BUFF = GET_BUFFER_STRING(strRESPONSE,2)
TEMP_BUFF = ''
ALBUM_DATA = GET_BUFFER_STRING(strRESPONSE,ATOI(nDATA_LENGTH))
FIREBALL_DATA[nFBLOOP].ALBUMS = ALBUM_DATA
ALBUM_DATA = ''
nDATA_LENGTH = ''
told you it was ugly--baby steps..
FYI- my code isnt THIS bad--the brackets got out of whack when i pasted the code??
Im starting to work on a string & command que, which is what i believe you are referring to. I indeed want to
1. bring in data
2. make sure i have a complete strings
3. process that data
4. clear out buffers
5. repeat.
i have quite a long way till i have something even partially working, but im really learning this way. Thanks again.
If you are just clearing data from the strRESPONSE buffer, there is no need to send it to TEMP_BUFF and then clear TEMP_BUFF.
GET_BUFFER_STRING(strRESPONSE,20) by itself will remove the data from strRESPONSE.
Saves a few lines of code and less is always more.
