How can I get Text Value from a button on TP?
How can I get Text Value from a button on TP? I have a button with a text inserted by the user by a numeric keyboard. How can I read the value?
Alex
Alex
"'?TXT-<vt addr range>,<button states range>'" Get the current text information. Syntax: SEND_COMMAND <DEV>,"'?TXT-<vt addr range>,<button states range>,<optional index>'" Variables: variable text address range = 1 - 4000. button states range = 1 - 256 for multi-state buttons (0 = All states, for General buttons 1 = Off state and 2 = On state). optional index = This is used if a string was too long to get back in one command. The reply will start at this index. custom event type = 1001: Flag - Zero Value1 - Button state number Value2 - Actual length of string Value3 - Index Text - Text from the button Text length - Button text length Example: SEND COMMAND Panel,"'?TXT-529,1'" Gets the button 'OFF state' text information. The result sent to the Master would be: ButtonGet Id = 529 Type = 1001 Flag = 0 VALUE1 = 1 VALUE2 = 14 VALUE3 = 1 TEXT = This is a test TEXT LENGTH = 14
