Sony FWD PX3 IP-Protocol and RS-232 problems
Hi all
With the new Sony Display FWD-50PX3 I have many problems:
// Controlling over-IP
- Did everybody know how i can control the Sony display over IP? I can't found a IP-protocol for this device. There is only a network port on board - for using RS-232 u must used the serial Slot Card - u can use only one card slot for adding Inputcards.
// Controlling over RS-232
- The RS-232 protocol works really well. But there is one big problem. The panel didnt answer me on any RS-232 commands after a hardware power down. I must first start the display manually (Remote Control) and then the communication works.
  • Onkelz wrote:
    Hi all
    I know a similar issue with Sharp LCDs. In the setup menu there is a position to disable this energy safe function (afaik in Japan it is not allowed to keep up RS232 control if the device is in standby).
  • OnkelzOnkelz Posts: 7
    Besten Dank Marc.
    Yes the Sharp LCD problem and the solution I know too. The difference for my problem is that i can turn off (standby) the display over RS-232 and then the "power on" command works! But after a hardware power down i can't start it again over RS.
