What modules are working well?
There has been much discussion on the quality of our modules. Please use this thread to list the modules that you are having success with.
Dyanlite v1.23
Lutron GraficEye v1.5
Roger McLean
Swinburne University
Now, working with the Apex Destiny 6100 was at first a pain, but then we got it all figured out. And it works very well - I don't care for the gobs and gobs of feedback, but it has worked well for us.
I've used both the NetLinx and the Duet Polycom VSX-8000 modules. The NetLinx module has a few holes and is getting out of date, but the passthru command comes in handy. The duet module appears to work pretty well, but my main customer still uses quite a few of the NXI masters that don't support Duet.
The Lutron netlinx module has worked very well for me, and after a little fiddling, the new Duet version seems to be working well. Altho, I vaguely recall having to mess around with my code to deal with the new way of handling keypad reporting.
The new Integra receiver module seems to be working well.
Of course, I treat all of the UI modules as simple examples for testing initial communication and as insight into the mindset of the comm module's author.
Denon AVR's and DVD's
DBX ZonePro 1260
Endeleo UDM-1604
HAI module works ok.
Viewstat comm module.
I've tried several Duet modules but didn't like any of them.
Lutron Homeworks
AMX Intercom- not that I had much of a choice - does generate an incredible amount of errors that should be fixed though
All of the Landmark modules - although there are lots of quirks
ReQuest module- with a few modifications, nice to have the source
HAI
Sim2 - disabling the cooldown and writing my own cool down function
Polk XM Tuner- as long as there is only one tuner works great - add a second and feedback stops after a time
I don't use modules for projo's for this reason, I always end up writing my own startup cooldown routine and I'm usually only ever turning them on and off and checking status anyway.
Destiny 6100
Jon's iPort Module.
AMX T-Stats
Have worked well for me.
Here's some third party modules that I've also had good luck with. I think it might give you some insight as to how others are doing it. The best thing about the ones I mention are that they are very good at handling multiple panel systems.
Kaliedescape - ( I do not like their UI and have modified it quite extensively)
ReQuest
The Sony VISCA module works like a champ.
--Audio Request from request
--iWeather
--iti aka Advent aka GE Netlinx security
--VantageQ works, but it is a little lacking
Really? Cause I just loaded up the Integra Module and it doesnt seem to control the Inputs or Tuner at all. WHen Querying the inputs it seems to be sending ?INPUTSELECT which of course the integra has no idea what that is....
VOlume Works Fine, Surround Mode works Fine, Power WOrks Fine.... But thats it for me.
