Bad IR file or goofy IR transfer?
jjames
                    Can someone try uploading this to their master? I cannot seem to get it to transfer without NS2 or IREdit crashing out. It's really starting to tick me off too.
Attached is the IR file and the CCF from which I made it from. It seems to crash out whenever I added room 3 or 4 off . . . it's aggravating though.
Hahaha!
Thanks Joe for helpin' out! Much appreciated!!
That is what I've had to do anyway.
Yup. I wrote out some CCF hex codes for Sony Control A1-II when I picked up a second hand receiver for home. I was pretty surprised when some didn't work even though the codes I'd written out were correct. Sticking a CRO on the output of the IR port confirmed that what the AMX was sending out was slightly different to what I had expected. I'm pretty sure the waveform view in IREdit was correct.
I remember there were at least two different scenarios whereby IR waveforms would be incorrectly imported from hex codes. In one scenario the output of the IR port would go high and stay high forever at the lead out of the IR code!
