TPDesign4 Properties Box
When in the properties box and you select an option such as changing the feedback type (momentary,channel,etc.) the drop down menu does not appear? Has anyone experienced this?
    No, but in a related issue, If I have a drop down menu active in TPD4 and click over to another program, the menu is orphaned and stays up over every other program and sometimes cannot be closed again by reselecting the drop-down and then closing it manually.
  • I have experienced what Mike described above. Usually this happens when I have TPD4 running on my second monitor. Switching TPD4 back to my main monitor fixes the issue.
