About Null or Not Null serial cable
HI
Sorry for this stupid question about serial cable but I'm confused.
Wish cable I have to use between my PC and NIxxxx controler, Null or not Null?
If I build this cable, I have to cross pin 2 &3 or I do a straight cable?
Thanks in advance
Thanks in advance
PC
Netlinx Master
2<
>3
3<
>2
5<
>5
Same connectors on Both Sides = Null
Opposite connetors = Straight throughThere are exceptions to any "Rule" but this is probobly 90-95% accurate.(Marantz...... Grrrrr.....)
Having said that, I've built a little inline adaptor, D9f to D9m. The Tx & Rx lines run through a DPDT switch, so at the flick of a switch I can cross & un-cross a null/not-null cable. I found it very useful for work in the field.
Roger.
