Sharp LCXXDXX RS232 protocol
Anyone has volume up/down RS232 command for Sharp LCxxDxx LCD TV? In the Sharp LCD Manual I have only stats the volume in level: VOLM** (volume0-60).
  • yuriyuri Posts: 861
    there are no RS232 vol up and down commands.
    Keep track of your volume, and send out VOLMxx
  • yanbinyanbin Posts: 86
    Thanks a lot.
  • flcusatflcusat Posts: 309
    yuri wrote: »
    Excuse my ignorance, but if you now the level at which the volume is; how that helps to ramp the volume up or down.
    flcusat wrote: »
    i don't understand...
    You have to build your own volume up/down routine, and use the VOLMxx command to send it to the LCD tv...
    Here's an example:
    DEFINE_FUNCTION fnVolAdjust(INTEGER nArgZone, INTEGER nArgState)
        STACK_VAR INTEGER nMyZone
        SWITCH(nArgState)
    	CASE 1: // Up
    	    IF(nZoneGain[nArgZone]<stZones[nArgZone].MaxLevel)
    		    nZoneGain[nArgZone]++
    		    IF(nArgZone<=6) // ZonePro 1
    			SEND_COMMAND vdvDBX1, "'LEVEL=1:O:',itoa(nArgZone),':',
    			    itoa(nZoneGain[nArgZone])"
    		    ELSE // ZonePro 2
    			nMyZone = (nArgZone-6)
    			SEND_COMMAND vdvDBX2, "'LEVEL=1:O:',itoa(nMyZone),':',
    	CASE 2: // Down
    	    IF(nZoneGain[nArgZone]>0)
    		nZoneGain[nArgZone]--
    		ELSE // ZonePro 2
    nZoneGain is updated with the current volume level in the Data_Event. This function increments or decrements then sends the new level to the device. This is for devices with no vol+ or vol- commands, where you can only send a level. TO emulate a ramp, you track the vol level in a variable, then adjust that variable and send it to the device.
    Looking at this code now there are cleaner ways of doing it, but it gives you a general idea.
