HOWTO: Double Push!!
A very simple function, but I consider it a good idea since most people used to the concept of Double Click, so why not having a Double Push
It still need more modifications
Any contributions are welcomed, and I will update the main post
DEFINE_FUNCTION INTEGER fnDblPush(INTEGER nBUTCHAN) { //nDBBUTTONS[] an array to indicate first or second push for a range of input channels //lDBBUTTONSTIMERS1 an array to store at what instant a channel has been pushed //lDBBUTTONSTIMERS2 another array to store at what instant a channel has been double pushed IF(DBBUTTONS[BUTCHAN]=1)//If it was pushed before?? { DBBUTTONS[BUTCHAN]=2//make this the second push } ELSE//if it was pushed twice before?? { DBBUTTONS[BUTCHAN]=1 //make it the first push } SWITCH(DBBUTTONS[BUTCHAN])//Now.... Which push is it?? { CASE 1://FIRST push { DBBUTTONSTIMERS1[BUTCHAN]=GET_TIMER //what time is it now? } CASE 2:// SECOND push { DBBUTTONSTIMERS2[BUTCHAN]=GET_TIMER//what time is it now? } } //If the time interval between the first and second push OR the second and first push is less than 6 tenths of seconds IF((DBBUTTONSTIMERS2[BUTCHAN]-DBBUTTONSTIMERS1[BUTCHAN])<6 OR (DBBUTTONSTIMERS1[BUTCHAN]-DBBUTTONSTIMERS2[BUTCHAN])<6)// then it is a DOUBLE push { RETURN 1 } ELSE { RETURN 0 //single push } } BUTTON_EVENT[dvTP,1] { PUSH: { LOCAL_VAR INTEGER DOUBLED DOUBLED = DB(BUTTON.INPUT.CHANNEL-40) SWITCH(DOUBLED) { CASE 1: { //DOUBLE PUSH ACTION } CASE 0: { //SINGLE PUSH ACTION } } } }
