Old AMX connectors
I just got an old AMX VSS2 Video sync sensor (year 1993 ?) and its female power connector looks like a recent AMX Netlinx connector, except it's bigger and 'rounded' on top and bottom...
Anybody having references about the male corresponding connector and where I could get some?
Thanks!
    Pep_SD wrote: »
    Thanks!
    You might look at this place. we get lots of phoenix connectors here.
    http://www.easyadapters.com/
    AMX still sells them too.
    They are called phoenix connectors, and the newer ones mini-phoenix. Last I looked, AMX could provide them. If you buy from a third party, make sure you get the right spacing between the pins, phoenix connectors come in various configurations. I was all excited when I came across a pile of connectors from another product that I thought I could use with the AMX, only to find the pins were a smidge farther apart, and therefore couldn't be used.
  • annuelloannuello Posts: 294
    The current connectors are 3.5mm spacing. The old ones are 5.0mm spacing.
    Phoenix connectors are available in the following spacings (mm): 3.5, 3.81, 5, 5.08, 7.5, 7.62, 10.
    This probably isn't a complete list. As you can see, 3.5 vs 3.81 doesn't look very different in a "parts bucket", but once this is repeated by 4 pins it adds up pretty quick.
    BTX Technologies sells them and you will get the most reasonable price from them. They are the 5.0 pitch.
  • Pep_SDPep_SD Posts: 106
    Thanks everyone for the info - got my order done!
