Lutron Lose connection
Hi guys
I am using Duet module to control lutron homeworks P5 system.
Its working ok, except the lutron lose its connection druing the night...
Every morning I come to work, the lutron is not responding to the the commands.
After loading the module again to the master - everything is working again (reboot the master not helping all the time, loading always works)
I removed the max module that works on the same master, to eliminate the ip problems.
I added SEND_COMMAND vdvLights, "'PASSBACK-1'" but I get nothing as response...
my login code that listen to the vdvLights :
OFFLINE:
send_string 0, 'Netlinx Virtual Device OFFLINE, please try to REINIT to reconnect'
ONLINE:
wait 50
SEND_COMMAND vdvLights, "'PROPERTY-IP_Address,192.168.10.151'"
SEND_COMMAND vdvLights, "'PROPERTY-port,23'"
SEND_COMMAND vdvLights, "'PROPERTY-Login,amx,control'"
SEND_COMMAND vdvLights, "'REINIT'"
send_string 0, 'Netlinx Virtual Device ONLINE.'
wait 50
wait 5 SEND_COMMAND vdvLights,"'LUTRONKEYPADADD-1,[1:4:4]'"
wait 10 SEND_COMMAND vdvLights,"'LUTRONKEYPADADD-2,[2:4:19]'"
wait 15 SEND_COMMAND vdvLights,"'LIGHTADD-3,[1:1:0:7:3]'"
wait 20 SEND_COMMAND vdvLights,"'LIGHTADD-4,[1:1:0:7:4]'"
wait 25 SEND_COMMAND vdvLights,"'LIGHTADD-5,[1:1:1:1:3]'"
* when in working state, pulling the network cable of the lutron gives the following errors:
Line 1 (12:00:12):: src.com.lutron.homeworksp5.dr1_0_117.LutronHomeworksp5: Communication Timeout Timer expired...!
Line 2 (12:00:12):: DDD.physicalDeviceOffline: unknown is offline
But nothing gets to my offline/online code.
** maybe I should listen to the IP device too? the real one ("dvActualLights1") the no the virtual??
Any idea how to start solving this issue?
Ady.
OFFLINE:
ONLINE:
wait 50
wait 50
Ady.
One day when I have some time, I'm going to have to clean up my Lutron module and share it here; it needs some quirks removed to be useable readily by others, but otherwise has been rock solid for me.
That was not what I wanted to hear...
Are you working IP or serial?
Whats recommended?
Any one else is working with the duet module with success?
I found the solution
The 252 channel is the online status of the lutron so the solution goes like this:
CHANNEL_EVENT[vdvLights,252]
OFF:
SEND_COMMAND vdvLights,??REINIT??
I will have to wait few days to see if this solve the problem, if not, well....
