persistent values in Modules
Hi, How can I memory persistent variables in Modules? I need to write in a file? How the files system work? Where can I find more information about?
Thank you
Alex
    OnkelzOnkelz Posts: 7
    Hi
    Sadly, persistent variables do not work in Modules!
    eddymouse wrote: »
    Thank you
    Alex
    You could write them to an XML file on the disk.
    mpullinmpullin Posts: 949
    ericmedley wrote: »
    I think the original poster knows this and is asking for details on how to perform file-writing skills within Netlinx. Since I've never done this I can't help any, sorry.
    eddymouseeddymouse Posts: 67
    mpullin wrote: »
    Exactly! Now I'm trying to follow the manual. But It's not so clear....
    Thank you!
    SensivaSensiva Posts: 211
    While waiting....
    Do as I am doing... while waiting for someone to provide detailed info, read NetLinx Keywords help ROUGHLY and THROUGHLY.
    click Help, NetLinx Keywords Help, in Index tab type file, and you will find FILE_COPY, FILE_CLOSE, FILE_OPEN, ....etc.
    I think after few hours of tryouts you will find out what's the deal with files operations in Netlinx, and then start your own "HOWTO: Files in Netlinx" thread, and I guess it will be a great contribution from you...
    AMXJeffAMXJeff Posts: 450
    eddymouse wrote: »
    Thank you
    Alex
    You can actually pass in a persistent variable to a module. The variable needs to be declared outside the module.
    PERSISTENT CHAR cWhatEver[100];
    DEFINE_MODULE 'Whatever blah blah' modBlah(vdvStuff, dvStuff, cWhatEver);
    I'll usually do what AMXJeff suggests and declare it outside the module, then pass it as a parameter. If it's something more complex, like a structure, or an internal database, I'll write it to a file.
