Denon DCM-390
mpullin
Has anyone in here controlled this 5 disc CD changer via RS232? I called Denon and they claimed Japan has not sent them the protocol, and Denon doesn't know when they'll get it.
There is a module on amx.com for the DCM-5000 (a larger 100 disc changer), but it doesn't seem to work with my DCM-390.
I checked out my Denon reps website and the protocols aren't listed for these models. Makes you wonder why after they go to the expense to add RS-232 capabilties to products and publish that fact and you know the protocols have to be developed because the products are shipping, they don't make them available and know one can give you information.
Yes, and that would make sense. Why re-invent the wheel. I haven't used the 1930CI but for $370.00 list and w/ RS232 it seems perfect for jobs that you just can't justify or swing the expense of a 3910ci or 5910ci.
But what about the new DCM 390 with RS232 list $350.00. There's nothing in there line up except that old DCM5000 that was discontinued years ago, where the 232 protocol for that? I would think that most of the commands use for the DVD palyers would also work.
I would just connect to it, create an input buffer and send it commands unfortunately you can't use the module for the 2900 as a guide as that communicates with the comm module through the virtual but if you get the Denon protocol for the 2900 and use that as a reference I'm sure most of the commands are the same as they relate to power on/off and transport. You may have to fiddle about to get the track commands and that should be about it. Denon uses straight forward ascii string commands so you could probably get something working in a little while.
The only plus side of this is that knowing when the device is powered on will allow me to learn its IR remote and turn it on or off without having discrete power functions! :-(
edit: so much for that idea, the remote has no power function whatsoever, not even a toggle.
Andre
I just wanted to see if anyone ever found a module for the Denon DCM-390.
