Get the system ID
Is there any function in Netlinx Studio to obtain the own System ID number? I need that information for my program to compare the number with some others because I'm working with 60 masters together...
Elena
    The system variable SYSTEM_NUMBER is supposed to contain this, though I must admit I've never used it.
    The system variable SYSTEM_NUMBER will give you the system number of the master the code is running.
    IF(SYSTEM_NUMBER = 3)
      // do something if the system number is 3....
    Another application
    dvMaster = 0:1:0
    INTEGER nMySysNum = 3 // the system number the master should have
    DATA_EVENT[dvMaster]
      ONLINE:
        IF(SYSTEM_NUMBER <> nMySysNum) // if the current system number differs
          SET_SYSTEM_NUMBER(nMySysNum) // set the new system number
          REBOOT(dvMaster) // reboot the system to take effect
    SYSTEM_NUMBER does give it to you. I use it all the time.
    System number
    Thanks! :)
