Home AMXForums Archive Threads AMX Hardware MAX by AMX
WinMax error
krukru Posts: 20
Hi everyone!
When i run WinMax program, it gives me this error:
"Error: 13
The following error occured:
Type mismatch
In Procedure GetSysInfo"
Does anyone meet the same problem? It also occured when i try to switch the "Music", "Movies" and "System Information" sheets.
  • IshlachiIshlachi Posts: 34
    I haven't gotten that exact error, but I do get different errors if I add an AVP while I am connected with WinMAX. I just have to reconnect. Could be an issue with network polling similar to the issue with touch panels on commercial networks locking up when telnet is active.
  • RincewindRincewind Posts: 5
    Артём, поставь в настройках винды регион и расположение США(USA). Всё будет пахать как часы.
    Someone in AMX company doesn't know about non-english encodings (such as win-1251(russian default encoding)). So non-egl speaking users must change their windows default settings (region and language defaults) to USA, other way WinMax will not work.
    ps
    to amx programmers - is it really hard to use utf8 ?
  • krukru Posts: 20
    Rincewind wrote: »
    Алекс, спасибо:)
  • pillboxpillbox Posts: 7
