^GLH or ^ BMF %GH commands work on Bargraphs but not buttons.
mush
G'day Guys,
I can set the maximum level of a bargraph at runtime using the ^GLH or ^ BMF %GH commands but not for a button linked to the bargraph for ramping purposes.
Anyone have the same issues?
Does anyone have a fix or a workaround?
Mush
Mush
SEND_COMMAND dvTP,"'^GLH-',itoa(nLevelNumber),',',itoa(nNewLevelValue)" ; //BUTTON CODE if(nLevel < nNewLevelValue) { //continue ramping code }Thanks for your time vining.
When I send the following to a 'bargraph' type button it works.
SEND_COMMAND vTP1,"'^GLH-1,200'"
But when I send it to a 'general' type button it does not work.
This is despite the fact that both types of button have the 'Range High' parameter, both buttons have
the same Address, Channel and Level ports and codes.
Cheers
Mush
Yes that is what I'm doing and yes I will have to scrub this approach which would have been much less work.
I guess the main point is that a described feature does not work fully. Not the first time.
