how to work with AXB-DMX512?
adysadys Junior MemberPosts: 395
Hi all
I have a new AXB-DMX512 connected to Ni3100
and I need to controll 3 set of leds
I have them declared as channel 1-3
I am trying to send command from my netlinx code like this:
send_command dvDMX , "'DR1L10%T10'"
nothing happens
the TX and RX leds are constantly on, I read that its ok, but they don't change when I send the commands...
Thanks for any help
Ady
  • Jimweir192Jimweir192 Junior Member Posts: 502
    Sounds like you may have the DMX512 wired up incorrectly. How do you have it connected?
    Are you using a daisy chain with an alternative 2nd DMX controller?
    You should also try SEND_COMMAND dvDMX, 'MZ' as this will do a reset and clear the memory.
    in all the systems i have seen, only the TX LED is constantly on...
    Correct, as DMX is a constant data-stream you should always have a Tx LED lit, having the Rx LED on suggests either a 2nd incomming DMX stream or a wiring fault.
  • adysadys Junior Member Posts: 395
    I have only DMX output connected . When disconneted it, the RX is off, but the TX is constantly on.
    removing the AXLINK wires and stay only with GND and + and still the TX is constantly on! even after reboot the box
    ( when connecting via ASLINK I see the box in netlinx onlin tree, so it connected ok....)
    I don't understand what is going on here
    Swap the DMX Output Data1+ and Data1- wires over.
    Ok
    Its working
    To turn on the dimmer I had to set one more channel that act as a master (channel 4) and now every thing is working...
    The 2 leds are constantly on BTW, but who cares :)
    Thanks for the help
    Ady
    what's sending DMX data then? another dimmer?
    I am not sure I understand , but only the DMX ouput of the AXB is connected to the dimmers, the input is not connected to anything.
