Zigbee Gateway Lockups
in AMX Hardware
Greetings,
I have an R4 in my house. Every week or so the NXR-ZGW locks up, requiring a power cycle. The R4 is not locked, just the gateway. All communication with the R4 is through the queing module.
Has anyone experienced lockups as I have desribed?
R4 2.61.30
R4 Zigbee Version 1.01.13
Channel is 19
Channel 19 was recommended by AMX tech support.
I would suggest trying a different channel to start. If you have it, or can afford to add it to the job, you might consider picking up a Wi-Spy device. It will show you if there is any interference present.
I'm glad you reminded me of that. When I originally set up the R4, I chose one of those channels. After talking with tech support, I was told that I could/would get better throughput on channel 19.
There is 802.11b/g in my environment. In fact the R4 cradle sits at the other end of the couch from an MVP-8400i.
http://www.xbow.com/products/Product_pdf_files/Wireless_pdf/ZigBeeandWiFiInterference.pdf
