Is it possible to....
in AMX Hardware
Can anyone tell me if its possible to lock-out/disable the program port of a master?
Full details are in the Netlinx NIxxxx Manual under security, be very careful though!!!
The RS232 terminal contains a secusity setup menu, from which you can turn off and modify the security settings. So personally I would let open the Programming port, because it is the last chance to reset the security settings if you lost your admin account data.
Thanks all for your replies... its oviously possible... but!
which leads to the next question....
Is it possible via code?
