Timeline Problem
Does anyone know why this timeline event does not trigger when I use the array that is commented out? It triggers if I specify the timeline id as shown but not if I use the array. Thanks.
DEFINE_CONSTANT LONG Camera_Sequence_TL[] = { 65204 ,65205 ,65206 ,65207 ,65208 ,65209 ,65210 ,65211 ,65212 ,65213 ,65214 ,65215 ,65216 ,65217 ,65218 ,65219 ,65220 ,65221 ,65222 ,65223 } LONG Camera_Sequence_TL_Times[] = {2500,5000,7500,10000,12500,15000,17500,20000,22500,25000,27500,30000,32500,35000,37500} DEFINE_EVENT // Camera Sequencing BUTTON_EVENT[dvTP,288] { PUSH: { nTP_NUM=GET_LAST(dvTP) // WHICH TP IS THIS? SEND_STRING 0,"ITOA(Camera_Sequence_TL[NTP_NUM])" TIMELINE_CREATE(Camera_Sequence_TL[ntp_num],Camera_Sequence_TL_Times,LENGTH_ARRAY(Camera_Sequence_TL_Times),TIMELINE_RELATIVE,TIMELINE_REPEAT) } } TIMELINE_EVENT[65204] TIMELINE_EVENT[65205] TIMELINE_EVENT[65206] TIMELINE_EVENT[65207] TIMELINE_EVENT[65208] TIMELINE_EVENT[65209] TIMELINE_EVENT[65210] TIMELINE_EVENT[65211] TIMELINE_EVENT[65212] TIMELINE_EVENT[65213] TIMELINE_EVENT[65214] TIMELINE_EVENT[65215] TIMELINE_EVENT[65216] TIMELINE_EVENT[65217] TIMELINE_EVENT[65218] TIMELINE_EVENT[65219] TIMELINE_EVENT[65220] TIMELINE_EVENT[65221] TIMELINE_EVENT[65222] TIMELINE_EVENT[65223] /*TIMELINE_EVENT[Camera_Sequence_TL[1]] TIMELINE_EVENT[Camera_Sequence_TL[2]] TIMELINE_EVENT[Camera_Sequence_TL[3]] TIMELINE_EVENT[Camera_Sequence_TL[4]] TIMELINE_EVENT[Camera_Sequence_TL[5]] TIMELINE_EVENT[Camera_Sequence_TL[6]] TIMELINE_EVENT[Camera_Sequence_TL[7]] TIMELINE_EVENT[Camera_Sequence_TL[8]] TIMELINE_EVENT[Camera_Sequence_TL[9]] TIMELINE_EVENT[Camera_Sequence_TL[10]] TIMELINE_EVENT[Camera_Sequence_TL[11]] TIMELINE_EVENT[Camera_Sequence_TL[12]] TIMELINE_EVENT[Camera_Sequence_TL[13]] TIMELINE_EVENT[Camera_Sequence_TL[14]] TIMELINE_EVENT[Camera_Sequence_TL[15]] TIMELINE_EVENT[Camera_Sequence_TL[16]] TIMELINE_EVENT[Camera_Sequence_TL[17]] TIMELINE_EVENT[Camera_Sequence_TL[18]] TIMELINE_EVENT[Camera_Sequence_TL[19]] TIMELINE_EVENT[Camera_Sequence_TL[20]] TIMELINE_EVENT[Camera_Sequence_TL[21]]*/ { send_string 0,"'sequence= ',timeline.sequence,' Timeline id =',itoa(timeline.id)" SEND_STRING dvAutoPatchOptima,"'CI',ITOA(TIMELINE.SEQUENCE),'O',ITOA(timeline.id-65203),'T'" }
--D
Check out tech note 657
