Question of timelines
Ok, I've tried it a few times and have discovered that I cannot get timelines to work if I use an array variable in their declaration. I was hoping for an explanation of why.
An example:
The following will not work:
BUT! This works just Dandy!:
Ok... Why?
Ignoring all the possible silly typos and stylistic jibber-jabber(I really need a Mr. T emoticon here!!), I don't see why this shouldn't work.
Isn't the value of TL[1] in the first exercise = 11? As a LONG Constant, the same TL1 (or 10+TWhich_Proj) in the second example?
The first example ALWAYS bogs the rest of the code following to a stop..... No more feedback and mostly poor performance. The controller though gives no indication of any problem in diagnostics or telnet messages.
I was just curious for enlightenment purposes.
Thanks in advance for the information.
An example:
Define_Variable (*Or Sometimes Define_Constant, neither works*) long Proj_Warm_TL[3] = {11,12,13} long Proj_Warm_Times= {60000} Define_Variable (*Always*) integer nProj_Sel integer Proj_On_Butt[] = {101,103,105} //Just for the sake of argument integer nProj_Pwr[3] integer nProj_Warm[3] //Fictitious Define_Subroutine Here designation Define_Call 'Projector On' (integer TWhich_Proj) //VERY Simplified for this exercise { If (! nProj_Pwr[TWhich_Proj] ) { on[nProj_Warm[TWhich_Proj]] timeline_create (Proj_Warm_TL[TWhich_Proj], Proj_Warm_Times, 1, timeline_relative, timeline_once) } } Define_Event Button_Event [tp,Proj_On_Butt] (*I KNOW I didn't define a TP here.... ASSUME it's a Touch panel that has been defined *) { Push: { nProj_Sel = Get_last (Proj_on_Butt) Call 'Projector On' (nProj_Sel) } } timeline_event [Proj_Warm_TL[1] (*Or even as 11*) ] { Off [nProj_Warm[1]] On [nProj_Pwr[1]] } timeline_event [Proj_Warm_TL[2] (*Or even as 12*) ] { Off [nProj_Warm[2]] On [nProj_Pwr[2]] } timeline_event [Proj_Warm_TL[3] (*Or even as 13*) ] { Off [nProj_Warm[3]] On [nProj_Pwr[3]] }
Define_Variable (*Or Sometimes Define_Constant you get it*) long Proj_Warm_TL1 = 11 long Proj_Warm_TL2 = 12 long Proj_Warm_TL3 = 13 long Proj_Warm_Times= {60000} Define_Variable (*Always*) integer nProj_Sel integer Proj_On_Butt[] = {101,103,105} //Just for the sake of argument integer nProj_Pwr[3] integer nProj_Warm[3] //Fictitious Define_Subroutine Here designation Define_Call 'Projector On' (integer TWhich_Proj) //VERY Simplified for this exercise { If (! nProj_Pwr[TWhich_Proj] ) { on[nProj_Warm[TWhich_Proj]] timeline_create ((10+TWhich_Proj), Proj_Warm_Times, 1, timeline_relative, timeline_once) } } Define_Event Button_Event [tp,Proj_On_Butt] (*I KNOW I didn't define a TP here.... ASSUME it's a Touch panel that has been defined *) { Push: { nProj_Sel = Get_last (Proj_on_Butt) Call 'Projector On' (nProj_Sel) } } timeline_event [Proj_Warm_TL1 ] { Off [nProj_Warm[1]] On [nProj_Pwr[1]] } timeline_event [Proj_Warm_TL2 ] { Off [nProj_Warm[2]] On [nProj_Pwr[2]] } timeline_event [Proj_Warm_TL3 ] { Off [nProj_Warm[3]] On [nProj_Pwr[3]] }
Ok... Why?
howsabout this...
Is that part of the SET_OUTDOOR_TEMPERATURE routine?
Now I know there is a definitive answer. I should check the tech notes more often, but oh well.....
And I was really looking for more of a timeline like this:
Ahhhhhh... wouldn't that be nice
But again, thank you all for replying, my curiosity is assuaged!
