Firmware V2.72.11 & FTP xfers !!!
It appears this firmware doesn't allow FTP or HTTP transfer from the master even when set up correctly in the resource manager. At least while using a NXD-1700VG.
See post.
http://amxforums.com/showthread.php?p=28108#post28108
I haven't tried to reload the firmware yet to see if it was possibly corrupt and maybe I'll just stay with V2.72.8 since I've waisted enough time.
See post.
I really wish AMX would start spending money on fixing all these bugs they keep dumping on us and not on buying new companies for awhile. I see bad things in the future if this continues!
I have several MVP-8400s with the newer firmware and they all have button feedback issues above 500.
The new firmware v2.84.17 for the 8400 fixes the button issue.
http://www.amxforums.com/showthread.php?t=4116
SET_VIRTUAL_CHANNEL_COUNT (DATA.DEVICE,1240)
Although it's a real device not a virutal it still seems to do the trick. I recall reading another thread posted some time ago where the poster used this on a real device to fix some problem, might have been the same problem but I don't remember.
Of course if they would fix the FTP issue on the newest VG firmware this never wouldn't have been an issue.
Does any one have any VG panels running the newest firmware that they can test retrieving FTP Dynamic Images from the master with. I'd like to see if maybe it's just me and not the firmware. Of course I could call TS and see if they've heard about or have seen this issue but I don't normally call TS for anything.
http://amxforums.com/showthread.php?t=874
Now if anyone w/ a VG Panel running v2.72.11 firmware can see if they can pull a ftp dynamic image from the master I'd be thankful again.
Joe Hebert wrote: Thanks for the confirmation Joe.
Now could some one at AMX put this on the ever growing list of things they need to fix! While you're at it if you could fix the old bug that required removal of password protection to get HTTP to work for Dynamic images from the master that would be appreciated too.
