Old Radias
                                  in AMX Hardware
                    Greetings,
I have had bad results using older Radia 4 and 6-channel boards on Netlinx masters connected via Axlink.
Most issues are communication related, requiring rebooting the dimmers. They worked fine on the Axcess-based systems they were removed from.
Any idaes?
Thanks.
Any idaes?
Thanks.
Replacement of a chip has helped with my case.
ORDER FREE FIRMWARE UPGRADE
Radia Master Firmware v3.22
Release Date September 28, 2005
This firmware is programmed into an E-PROM chip and not available as a download. Please order the free replacement chip using part number: PC606-A.
NEW FEATURES
Improve ProLink interface error detection and message handling.
Add new phase/zero-crossing detection and correction features at startup and reset.
This firmware reduces AxLink controller lock-ups and Radia devices from dropping off line.
What firmware did you replace out of your dimmers?
