MVP5200i USB xfers?
Is this not supported yet or am I just completely brain dead? I have a MVP5200i that will not do IP transfers. It starts but never finishes for both TPD4 file and firmware files. Tried USB and couldn't get it recognized and displayed in the device tree. Tried USB on a 5200i TP that does IP fine and still no joy. Tried changing my USB IP addresses and put the virtual master on the same range as the panel but no joy.
Is there a secret sequence that I'm not aware of?
Then I tried to connect for a firmware tranfer via NS2 and it ran its query to see if the target device was online and just as before the progress bar was going and going just as before and I thought for sure it wasn't working again and started searching the AMX site for references to USB file transfers and after abouty a minute or two I noticed my TP started receiving files. Hallelujah!!!
Tried this again on the questionable TP and the firmware transferred w/o a problem. Switched over to IP comms and TPD4 and those file transferred w/o problems. So the firmware seems to have fixed the problems but getting it done wasn't any fun at all.
I'm not sure if IP over USB is any better than just USB. Hopefully I'll remember this procedure next time I have to go through this crap!
