how to control swimming pool
in AMX Hardware
Hi all
Anybody try to control swimming pool if anybody did so plz help us witch hardware we can use.
I have NI-3100 and MVP-8400 I want to show on panel water temperature and control
EVERYONE_OUT_OF_POOL,EVERYONE_IN_POOL keyword...
Part numbers are Jandy Aqualink and Jandy Aqualink RS Serial Adapter.
Link to Manual
--John
Take for instance a simple Aprilaire or Viewstat thermostat. You would think that any mechanical contractor would know how to properly install one of those, but you'd be amazed at how many contractors will screw it up. Then they complain to whoever will listen about the piece of crap you spec'ed and every time there's a problem they point to you. When you choose a piece they're familiar with then things tend to go smoother and you don't end up being the company that has to service every thing to do with their subsystem.
When it's possible I prefer to go with a device that's simpler and familiar to the trade responsible for installing and servicing the device rather than an exotic piece that causes them to point fingers the first second they get confused.
--John
I would also agree with John on getting a device that other trades are familiar with. I even take it so far as to let them acquire it so that they don't think my hand is in their pocket.
I hear all they do is link to SET_OUTDOOR_TEMP.
Does anyone have the command set parsed out or some basic code to get started? I inherited a job where they put Goldline Aqua Connect in lieu instead of Jandy or Pentair.
