Writing and Reading Flash
Greetings,
Getting things on and off the flash is something that still elludes me.
Could someone give me some example code for writing an integer variable value to flash and then reading it back into that integer variable.
Thanks!
  • AMXJeffAMXJeff Posts: 450
    You do not need to use VARIABLE_TO_STRING AND STRING_TO_VARIABLE, but I believe this is the best way to write any variable to flash, end of soap box.
    TEST
    DEFINE_FUNCTION WriteIntegerFlash(CHAR cFileName[], INTEGER nValue)
    	STACK_VAR SLONG slFileHandle;
    	STACK_VAR CHAR cConvertedValue[100];
    	slFileHandle = FILE_OPEN(cFileName, FILE_RW_NEW);
    	// VALID FILE HANDLE
    	IF (slFileHandle > 0)
    		VARIABLE_TO_STRING(nValue, cConvertedValue, 1);
    		FILE_WRITE(slFileHandle, cConvertedValue, LENGTH_STRING(cConvertedValue));
    		FILE_CLOSE(slFileHandle);
    DEFINE_FUNCTION INTEGER ReadIntegerFlash(CHAR cFileName[])
    	STACK_VAR INTEGER nValue;
    	slFileHandle = FILE_OPEN(cFileName, FILE_READ_ONLY);
    		FILE_READ(slFileHandle, cConvertedValue, MAX_LENGTH_STRING(cConvertedValue));
    		STRING_TO_VARIABLE(nValue, cConvertedValue, 1);
    	RETURN nValue;
    DEFINE_PROGRAM
    WAIT 100
    	TEST = TEST + 10;
    	WriteIntegerFlash('test.dat',TEST);
    	SEND_STRING 0,"'INTEGER=',ITOA(ReadIntegerFlash('test.dat'))"
    Good Stuff!!
    DEFINE_FUNCTION WriteIntegerToFlash (CHAR cFileName[], INTEGER nValue_)
    slFileHandle=FILE_OPEN(cFileName,FILE_RW_NEW)
    IF (slFileHandle>0)
        VARIABLE_TO_STRING (nValue_,cConvertedValue,1)
        FILE_WRITE (slFileHandle,cConvertedValue,LENGTH_STRING(cConvertedValue))
        FILE_CLOSE (slFileHandle)
    ELSE
        SEND_STRING vdvDVM,"'FLASH FILE WRITE ERROR ',ITOA(slFileHandle)"
    DEFINE_FUNCTION INTEGER ReadIntegerFromFlash (CHAR cFileName[])
    STACK_VAR INTEGER nValue_
    slFileHandle=FILE_OPEN (cFileName,FILE_READ_ONLY)
    IF (slFileHandle>0)
        FILE_READ (slFileHandle,cConvertedValue,LENGTH_STRING(cConvertedValue))
        STRING_TO_VARIABLE (nValue_,cConvertedValue,1)
        RETURN nValue_
    ELSE
        SEND_STRING vdvDVM,"'FLASH FILE READ ERROR ',ITOA(slFileHandle)"
    WriteIntegerToFlash("'CHANNEL',cDeviceNumber,'.dat'",nValue)
    nValue=ReadIntegerFromFlash("'CHANNEL',cDeviceNumber,'.dat'")
    Above is what I created with your help. Unfortunately, my return value is always zero, although the correct file name is created on the flash. Any suggestions? Thanks!
    Well what's the value of nValue when you call the function "WriteIntegerToFlash()". For testing you might want to add some more SEND_STRING 0's or step through it in debugger.
    vining wrote: »
    It's non-zero (46 to be exact). send strings back to the master result in zero.
    Change this:
    To this:
    FILE_READ (slFileHandle,cConvertedValue,MAX_LENGTH_STRING(cConvertedValue))
    Or this:
    FILE_READ (slFileHandle,cConvertedValue,100)
    And you should be good to go.
    When cConvertedValue is declared it has no length so FILE_READ was asking for a max of 0 characters which will get you nowhere fast.:)
    Joe Hebert wrote: »
    I'm good to go! Thanks, works like a champ.
