Home AMXForums Archive Threads AMX Hardware MAX by AMX
shutdown MAX via Netlinx
Hi. Can I shutdown Max server via Netlinx Code?
Thank's a lot
Alessandro
    eddymouse wrote: »
    Thank's a lot
    Alessandro
    Yes,
    I'm not at my machine right now to give you the exact code. But, I think it's something like Power=0.
  • By a send_command ?
    thank
    eddymouse wrote: »
    By a send_command ?
    thank
    Yes, send_command vdv_MAX_Module
  • bobbob Posts: 296
    telnet to the control port and send a string "poweroff"
  • John GonzalesJohn Gonzales Posts: 609
    Just to note, if you issue the POWER=0 command to turn off the server, you have to manually turn it back on. It can't be turned back on by code.
    If you're trying to turn off the AVP and not the server then you could issue the commands below (where nZone is the AVP that you're trying to control):
    Send_Command vdvMAXModule, "'AVP_KEYS=',ITOA(nZone),':45'"  //Turns the AVP off
    or
    Send_Command vdvMAXModule, "'AVP_KEYS=',ITOA(nZone),':44'"  //Turns the AVP on
    --John
