Hot glue guns
Which hot glue gun and sticks do you use and can suggest? I am going to stick IR emitters with this, facing hot temperature issue, they coming off... Thank you in advance.
Update: Am I correct that I need a low-temperature gun?
I actually don't use the glue gun any more and just use a drop or two of crazy glue instead. The emitter can be pryed off later fairly easily if the device needs to be replaced or repaired like the semi annual HD DVR cable box replacements we experience with the Scientific Atlanta 8300 HD boxes.
http://www.acehardware.com/product/index.jsp?productId=1419007
http://www.doityourself.com/invt/8822496
No hot glue required.
nuff sed
