LG Plasma 42PM4M
Does any one have experience programming LG 42PM4M. I can turn the power on only through serial command and after that I have an error on all commands. I could not turn the power off, selection of sources...
There are many, many threads here on LG displays and the various quirks; I'd do a search on LG and run through those.
We've run into LG Plasmas which stop responding correctly if you're sending commands when power is applied to the unit. Not sure if your code is polling the unit for feedback and was trying to put it in a known state when you plugged the power in.
We use one way control with them as a general rule for this reason.
after changing the rs232 board,, its working now with the codes... (source selection, power off),, thanks for help..
Once I was using the baud rate 9600,N,8,1 and I just could turn on the LG all the other commands only work if when I changed the baud rate to 115200,N,8,1
Try do that ... I supose you are with the same problem.
Let me kno if it worked!
Cya.
