Debug Problem
ondrovic
When I try and use the debug option in NS I get this error :
Under Preferences ---> Netlinx Complier I have Compile with debug info and build with source
I have loaded different code into the same master ( another project ) and debug works fine
I have also done a format disk on the master as well as a clean disk and re uploaded the source code
Any ideas??
The complied TKN file on the master controller does not match the source code file that you have selected to debug with Do you wish to continue?
Any ideas??
Kevin D.
