Home AMX Control Products
5200i - slow transfer!
What's up with the SUUUUUPER SLOOOOOOW transfer? My gosh!!! Transferring our files to the 8400 is slow enough, and now make it even slower is making my transferring experiences horrendous!
Anyone else noticing this?
    Seemed the same to me as an 8400 last one I did.
    Transfers are fine with my 5200i also.
    jjames wrote: »
    the two I've done are just fine...
    hmmmm...
    Must be the network . . . because we're now having some other issues.
    But even the one on my desk here seems to transfer slower than the 8400 I have sitting next to it.
    I'll have to run some tests later and see if it's a figment of my imagination or not.
    No issues here either. I am annoyed that you can't preview 5200s but that's another thread.
  • 5200i Preview
    You can panel preview a 5200i, but you need to open the file directly with G4 Panel Preview, and not through TPD4. (and hence, need to close the file in TPD4, but you can do it)
    Adam
    jjames wrote: »
    I have noticed that the wireless range on the 5200 is definitely less than the 8400 (newer 8400s). Maybe the 5200 is running at 2Mbps and the 8400 is running at 18Mbps ... or something like that?
    Adam
    Thanks Adam I will check that out.
