Using while loops within data_events
I've been warned about the use of while loops within the processing of data_events as it supposedly stops mainline execution whilst the loop is operating. Is this true, or am I being had?
Basically I've got a structure set up that I'm keeping device state information in. Occasionally the device will spit a string of commands at me and I need to be able to process them all in the most efficient way.
Currently I've gone down two routes:
In the first case I set up a while loop that iterates through DATA.TEXT removing and processing each command found. This seems to work a treat and is nice and neat, with minimal code.
The alternate option I've explored is passing the received data into a buffer, and processing one event per run off the mainline, if there's anything in the buffer. This is achieved by setting up a call to remove and process the first command currently in the buffer. Doing it this way also *works* (functionally speaking) however it introduces a good 3 second delay into the system.
My question is, is processing all data received (135bytes max length for this device) in one hit when it is received some horribly sacrilegious action in the world of AMX?
All that being said, I don't think there is any problem in using a while loop as you describe it.
I would be interested in seeing the code you are using for the mainline implementation tho. There shouldn't be a 3 second delay with the mainline version unless you are doing a lot of processing.
My mainline in my master axs then is just doing a couple of button updates to my panel.
I don't write code like that because I don't want a loop to continuously run in mainline when 99.99% of the time the buffer will be empty. Why not call your function directly from the string event once you have a full command string?
Btw, you can use invariants to make sure your while loop always terminates.
Calling the function from the string event is not possible as multiple command can be passed in on the one string, and as such I'd have to use a while loop within that function to loops through each command, which is essentially what I'm doing at the moment, but with the loop within data_event.
The first thing I'd do is test to see how many times your loop is actually running. Create an integer variable, and immediately before the loop starts, set it to 0. Then make the first line of your while loop nInteger++. Watch your integer in debug and see what happens. If it only increments a little bit, then your loop is probably fine.
If that shows some strange variation, the next thing I would try is declaring a stack_var and setting it equal to data.text, then using it for the duration of the loop. Sometimes data.text does strange things, especially when you start removing characters from it.
You might also try putting the following line in your define_program section
If define_program is running correctly, that will output the line "Heartbeat" to diagnostics every half a second. You can watch that during the while loop to see if it is affected at all.
J
This would give you an ideal of how taxing your code is to the processor.
I think you answered your own question, no?
@kbeattyAMX
It's not actually a module, this is just an include as the place I'm working at doesn't like modules due to their 'lack of expandability'. If I had my way I'd be using them as they are there for a (good) reason, however I'm the new guy so I'm just trying to keep to the already established coding styles as it makes things easier for everyone
Thanks for cluing me in to that one, PhreaK...
Maybe you should just write the code the way you want to write it and install an all-caps font on your boss's computers.
http://www.dafont.com/barrelhouse-all-cap.font
otherwise, I don't
You can increase the size of the font if your eyesight is not great. Using all caps is harder to read due to the lack of word shape clues.
