VNC into panels - security
 Pep_SD
Pep_SD
                    How do you guys deal with security when using Vnc to connect to panels?
I tested one of these DNS service that provides you with a DNS name when you don't have a fix IP for your home network and used it to connect form outside my network to a touch panel.
But I don't see any kind of login/password to access to the G4 web console...
Is there a way to add a minimum of security?
Thanks!
Paul-Eric
Thanks!
Paul-Eric
Thanks Vining!
Now I feel bad for not even having checked back on the panel configuration itself...
