How to connect STOP on projector screen to NI3100 relays
                                  in AMX Hardware
                    Hi
I have 4 wires coming from the Da Lite 150 "screen UP,DOWN,GRND,+5V
My problem is how to connect to the relays a STOP function in the NI3100 relay ports.I want to know exactly what goes where
Right now i have the NI3100 setup like this
Projector Lift up- Relay 1 (UP,GRND)
Projector Lift Down- Relay 2 (DOWN,GRND)
Projector Screen Up-Relay 3 (UP,GRND)
Projector Screen Down - Relay 4 (DOWN,GRND)
Projector Screen Stop - ?
Ajay
Isn't maybe
Projector Lift up- ON[Relay, 1] (UP,GRND)
Projector Lift Down- ON[Relay, 2] (DOWN,GRND)
Projector Screen Up- ON[Relay, 3] (UP,GRND)
Projector Screen Down - ON[Relay, 4] (DOWN,GRND)
In this case, the screen (or lift) will stop when you will switch OFF[Relay, 3] AND OFF[Relay,4]
Most of the screens I have worked with will only drive the motor for the time you have a closure (as opposed to pulse), and, will stop as soon as you open the relays.
The motor should also have stop-switches so it releases when the up most/bottom most position has been reached.
I think you will also agree that you must take some precautions in programming for avoiding the simultaneous closure on both UP and DOWN relays.
Here is the info on how I wire and program it.
AMX relay:
1A- GND, buss strip to 2A and 3A.
1B- UP, diode to 3B
2A- GND
2B- DOWN, diode to 3B
3A- GND
3B- STOP, 2 diodes from 1B and 2B
I use a small glass diode, NTE-519, I connect the leads from the 2 diodes nearest the black line together and tie them to 3B. The 2 remaining leads then goto (1 lead each) 1B and 2B
I pulse the relay in the direction that is required and after a wait (this will vary depending on screen size) I will pulse the stop relay. Hope this helps.
much appreciated
