Axlink bus is dead?
 bob
bob
                                  in AMX Hardware
                    I have pulled a serial cable of a component (the other side was attached to an AXC-232 card) and the netlinx master did a beep and rebootet. I have never had such a behaviour. Now the Axlink bus is dead, no device on the bus blinks, no TP responds. The master responds fine though and is able to reboot and download the program, but the AXlink isn't operational anymore! The master still blinks Link and Status green LEDs. The green LED on the card server card in the ACCESS cardframe lights constant!?
Anyone have a suggestion what I might do? I have a NI-700 master with associated AXCESS cardframes and other AXB devices and everything was working for a long time. I have swapped the CS card in the cardframe and also other cards but nothing. The AXlink bus is ust dead and no AXlink devices shows up in Netlinx Studio when I refresh the system!
I've never seen an NI700 (or other NI controller) with bad Axlink, ao I can't offer any assistance in trouble shooting if it turns out to be the NI700. My wag is that the Axlink on an NI700 is not field serviceable. I have seen cases where a device on the Axlink would kill it. I seem to recall a Radia installation a couple years ago that we had trouble with. Also had a new from AMX G3 tp that would kill the Axlink when connected.
Axlink communications seem to be pretty robust. Every once in a while an installer will connect something wrong and it will kill communications but it always seems to be OK when connected properly -- I've never seen anybody actually damage an NI controller by incorrectly wiring an Axlink device including shorting the wires. So, maybe it will turn out to be just one Axlink device or a single card in your Axcess card frame.
It's best to isolate the problem as much as possible. I'd make a cable and plug the G3 touch panel's axlink straight into the master and see if it comes back.
either way, I'd call tech support.
- NI700 axlink light blinks ok when I disconnect the axlink cable from the master. blinks still ok when I reconnect the bus again and shows devices.
- I have pulled all AXC cards out of the cardframe. When I put only the CS card into the cardframe, the green light lights constantly and bus becomes dead again.
The CS card is what determines the addresses of the cards in the frame. (Card Server)
You might try looking at the dip switch settings on the card. Perhaps they've been altered in some way. Also, the card could have gotten zapped somehow.
Also, I'm assuming you have no Master in the frame. right???
Does it make sense to swap the cardframe itself? I have another one lying around. Does it have anything active on the backplane which may have been shortended?
I have pulled all the AXC cards and both CS cards I have tried constantly light green and the bus dies when I insert any of both CS cards (all other AXC cards removed).
I just noticed that without the cardframe the bus gets actualy splitted, i.e. half of the devices don't get power at all and the other half work correct. Checked that AXlink connectors and gotcha, it was a shortage there and because there go two axlink wirings to the cardframe as soon as it gets activated the whole bus shortens and disappears (the cardframe acting as a bridge between both halfs). So pulling he serial control cable from the a/v prepro and the shortenage in one of the bus strips at the same time must have been a pure accident in time.
Thanks MUCH to all who responded!
