Loading new .tko via ftp
Hi there!
I have 2 very interesting questions:
1. Is it possible make this procedure:
If I send to Netlinx FTP server new compiled tko file, it takes it after restart and change previous version of program.
2. How can I send telnet commands via Netlinx.
I found by myself interesting TechNote http://amx.com/techsupport/techNote.asp?id=286
2) Open a TCP/IP socket in code and send away... The TechNote you indicated gives you the code example for this TCP/IP Socket. But if you want the same information, just use the keyword GET_IP_ADDRESS;
I dunno - perhaps that's what he's going for - I know I am.
It is doable if you connect the remote master to one that is accessable. Then you can device map through to the hidden one. I houses where I have multiple masters, I make sure to create a device for the sub-masters so I can send code to them too. That way I don't have to port forward all of them.
I suppose one could connect the remote master to something like I have in the mothership. It's a Netlinx master here at my office.
I wouldn't want it to stay connected all the time. but you could write in the code to connect up at certain points and be ready and standing by when it's connected.
I dunno, I can think of lots of ways to make something like that work.
Yeah - that was my other option. Having the master connect to the one here at the shop and send via M2M - but didn't know if that's possible.
Yes, that is very much possible.
Sounds good - I'll play with that today and see if I can get it to work. Now for the real problem - having the guys here at the shop leave my processor alone and quit swapping! I saw one on ebay that was super cheap - wonder if the boss would buy me one so I can have one here 100% of the time.
Mine is an ME-260. It's pretty much worthless to the techs.
You may have difficulty connecting to some telnet servers using this tn example. For example, the telnet server that comes with Windows XP Pro will not allow the connection. There was a discussion thread about this topic some time ago which explains how to go about figuring this stuff out:
Telnet--Ethereal thread
Haha - nice! I need one of those.
AMXJeff. I want to find easy way to update program file from anythere. Now I'm in client's house, but soon I go.
I got it to the point where I can load code remotely, but is there a way I can check variables, watch diagnostics, notifications, etc.?
If you're able to connect remotely via NS2, then all the other stuff should work. It's not all that fast, but it works. I'll quite often have debugger open wathcing variables while the client is using their system.
... but I'm kinda nosey that way...
Yeah - when I'm connected though, It shows me the variables loaded on the main master and not the master that's connected remotely. I have it connected like so:
M2 ---> M2 <--- Me
I can only see M1's variables & diagnostics, but can do online trees for M2.
I wonder if a person could do a
DATA_EVENT[local submaster port 1] { string: command: etc... { send_string(main_master), data.text } }If you meant "tkn", i.e. a compiled program, then yes. I just did a writeup for the benefit of our service techs. The basic idea is that you ftp to the master, then PUT <your_program.tkn> to ../PROG.TKN. Then telnet in and reboot.
For now, my writeup is at http://www.monochrome.org/amx/amx_upload.html
Also possible. Use ip_client_open to the IP address of the server (or equipment), typically to port 23. Once the connection is established, you can send and receive strings as if to an RS232 device.
If you use the master's own IP as the target IP (127.0.0.1 should always work), you can issue commands to the master from your program as if from a telnet session. Fun stuff.
HTH.
