Sending IR files... reboot necessary?
in AMX Hardware
Am I loosing my mind, or did the processor used to require a reboot when changing the IR files? I just sent some IR files and was waiting to reboot until after I verified a couple of the new boxes actually had video when I hit one of the buttons out of habit. I was SHOCKED to see the unit respond.
For some reason, I had it in my head that changes to IR files required a processor reboot in the past. Was this the case?
P.S.
This will save me about 3 hours today and it does make me a little happy
P.S.
This opens up a whole new world of possibilities for me
- Amazed by the simple things in life since 1976
As long as you are not losing your mind you should be ok.
P.S. when in doubt, reboot should be your first choice.
Same here. 99% of the time., just loading it is fine. Yet, that 1%, when it didn't work right away, it did after a reboot. I was never able to discern a pattern as to when this happens.
