extron switcher mps 112 problem
in AMX Hardware
I m not able to control the extron switcher thru the amx touch panel.
The rs 232 is working because thru notifications i can send and recieve the messages
i have defined the device
dvExtron =5001:2:0
dvTpExtronMVP7500 =10001:2:1
and my extron code is
PROGRAM_NAME='IncExtron'
INTEGER Index
char Sbuff[40]
INTEGER nExtronbutton[] =
1,2,3,4, // VGA
5,6,7,8, // S- video
9,10,11,12 //video
create_buffer dvExtron,Sbuff
DATA_EVENT[dvExtron]
online:
// Set Baud for Projector
send_command dvExtron,"'SET BAUD 9600,N,8,1'"
BUTTON_EVENT[dvTpExtronMVP7500,nExtronbutton]
push:
Index = GET_LAST(nExtronbutton)
SWITCH(Index)
CASE 1:
// VGA
send_string dvExtron,"'1!'"
break
CASE 2:
// VGA
send_string dvExtron,"'2!'"
break
CASE 3:
// VGA
send_string dvExtron,"'3!'"
break
CASE 4:
// VGA
send_string dvExtron,"'4!'"
break
CASE 5:
// S-video
send_string dvExtron,"'5!'"
break
CASE 6:
// S-video
send_string dvExtron,"'6!'"
break
CASE 7:
// S-video
send_string dvExtron,"'7!'"
break
CASE 8:
// S-video
send_string dvExtron,"'8!'"
break
CASE 9:
// video
send_string dvExtron,"'9!'"
break
CASE 10:
// video
send_string dvExtron,"'10!'"
break
CASE 11:
// video
send_string dvExtron,"'11!'"
break
CASE 12:
// video
send_string dvExtron,"'12!'"
break
i think the code i m sending to the extron switcher is not recognized by it
can anyone help me in this ,this is my first program.
dvExtron =5001:2:0
INTEGER Index
char Sbuff[40]
1,2,3,4, // VGA
9,10,11,12 //video
online:
push:
SWITCH(Index)
CASE 1:
// VGA
break
CASE 2:
// VGA
break
CASE 3:
// VGA
break
CASE 4:
// VGA
break
CASE 5:
// S-video
break
CASE 6:
// S-video
break
CASE 7:
// S-video
break
CASE 8:
// S-video
break
CASE 9:
// video
break
CASE 10:
// video
break
CASE 11:
// video
break
CASE 12:
// video
break
example
thanks to all for your help
Does this problem exist for SEND_COMMANDs to any device in its ONLINE: handler or is it strictly an RS-232 port problem?
