Needing Color Viewstat help
I'm getting started on code for the new ENV-VST-C thermostats and I'm confused by the reference guide. I've never programmed any Axlink devices before so I'm not sure what to do with the channels that the guide lists.
For example, 140 is Increment Cool Set point.
So do I do:
And is feedback from the tstat all done through levels or will it send me strings?
I don't have Viewstats at the shop right now to do trial and error on.
So do I do:
SEND_COMMAND dvTstat1, 'CMD 140'or am I supposed to turn the channel on and off similar to doing button feedback?
Nope, you would pulse the channel like this:
PULSE[dvTstat1,140]
Levels are used to report the temperatures and set points as per the manual on page 28. The heat and cool setpoint levels are listed as for both command and feedback, however, I was only able to get the levels to work for feedback. To change setpoints I had to use the MD SEND_COMMAND on page 24.
Channel events are used for control and feedback as listed in the manual.
There are strings that come back but I think levels and channels give me the feedback I need.
Hope some of this helps.
I had already started coding that way and thought that I would have to use ON[X,X] for sure and was guessing PULSE[X,X] would work for increment & decrement, but wasn't 100% sure.
The MD command info will definitely save me some troubleshooting.
Thanks Joe!
Axlink_Level *100/255 = percent_level
solve for what you need. It even does the rounding for you.
Right, but the thermostat gets it relative humidity data for display by means of an Axlink level. So the RH can only be 30, 29, 28 (look out Toto!)
That's right. Relative humidity is generally expressed in hundreths. xx.xx
I have no idea how to get there with an Axlink level.
