service due to server degradation
                                  in MAX by AMX
                    MAX is giving a message box (in TP and in WinMax Both)
"!!!!!!!!!!!!!!!!ATTENTION!!!!!!!!!!!!!!!!!!!!!"
Your max server requires service due to system degradation.
Contact your amx dealer immediately.
Failure to contact dealer may cause a loss of content.
Any idea what is it?
Ady.
Ady.
Get into the maintenance console, and check the RAID status, it should tell you which drive has an issue. If it's not obvious from there, restart the server, and watch the SCSI card report as it boots up. Once you isolate the drive, just pop it out of the frame and pop it back in. Unless it has really gone bad (unlikely), it will come back on line and the array will rebuild itself.
Raid status is ok, all HD are online
Restart server solved the problem for now
We are too after 2 Hard Disks replacement... after less than one year in residential use, and our server has UPS too...
